Hi everyone,
I would like your input on a decision we have to make at OpenKIM.
This is a follow up on a discussion @akohlmey, @tadmor and I had a few weeks ago. OpenKIM will be adding many more LAMMPS Simulator Models (SM) with long-range electrostatics soon. If you are unaware, a KIM SM is essentially an encapsulation of a set of LAMMPS commands and parameter files. See, for example the model-init and model-defn keys in the following SM specification (which does indeed include long-range electrostatics):
https://openkim.org/files/SM_328512278696_000/smspec.edn
Some of the commands are internal KIM commands, so they may be unclear, but hopefully you get the idea.
KIM SMs should be as straightforward as possible for the user to deploy and work under as many conditions as possible, which is where the difficulty comes in – as demonstrated in the example, different periodicity settings require different settings for pair_style, kspace_style, and possibly kspace_modify.
We use conditionals to cover as many cases as possible, even though obviously we cannot cover all possibilities. To aid in these conditionals, the KIM LAMMPS package defines some LAMMPS variables in order to expose information about the state of the simulation to the LAMMPS commands in the SM (for example, kim_periodic). We can put new variables like this into the KIM package if required.
Here is a summary of what the linked example does (with some elaboration to understand implications to other cases and other types of SMs). I think it is a reasonable solution and I propose continuing to use it, but I wanted to run it by the community before we commit to this solution for new models:
- If the box is nonperiodic, use the
/coul/cutversion of thepair_stylewith a cutoff equal to the diagonal size of the box (if/cutis not available, as in/cspair_styles, use/wolfwith a damping of 0 to replicate the behavior of/cut). - If the box is 3D periodic and contains charges, use
/coul/longandkspace_style pppm - If the box is 2D periodic, add
kspace_modify slabto 3) - Do not provide any special support for 1D periodicity. Leave it as
/coul/longandkspace_style pppmwith no other modifications. This means that, nominally, KIM SMs do not support 1D periodicity, but the user does have the option of issuing their ownkspace_modify wirecommand (which I understand is far from the ideal way to do 1D Coulomb, but it both provides a workaround for advanced users, and avoids inexperienced users unknowinly using inadvisable simulation settings).
What do you think? Is this the best option to cover as many cases as possible, or does anyone have ideas for improvement?
Cheers, ilia
