Dear LAMMPS users and developers,
In order to switch off the interactions between two groups (one atom type in a solid slab and liquid molecules placed atop the surface), I’m using a hybrid pair_style, with one being “lj/charmm/coul/long” (among solid-solid and liq.-liq. particles) and the other “lj/cut/coul/long/soft” (one solid atom type-liquid). Regardless of the value of the coupling parameter used for the latter style, the surface is very unstable, such that the top-layer atoms tend to move into the liquid phase. I don’t run into this problem when using only the “lj/charmm/coul/long” command (which is the full-interaction case). Could you please let me what I’m doing wrong here? I assumed the easier alternative approach is using the “neigh_modify exclude” command, however that didn’t work either.
I’d appreciate your comments.
Monir
