Dear LAMMPS users,
I am attempting to post-process some GCMC simulations generated with the DL_MONTE simulation software using LAMMPS’ rerun
feature. To do this, I use a python script to transcribe DL_MONTE output files into LAMMPS dump files.
The simulation is of gas adsorption in a MOF, and my only pairwise interactions of interest are intermolecular gas-gas and gas-MOF interactions. To this end I have attempted to switch off any unwanted interaction pairs with the neigh_modify exclude
command:
neigh_modify exclude type I J
for unwanted MOF-MOF interactions, andneigh_modify exclude molecule/intra gas
for intramolecular gas-gas interactions.
While the former exclude statements appear to be working, my simulated interaction energies are not changing when the latter statements are turned on/off. I believe this is an issue with how I’ve transcribed different molecule types into the dump file. Please could you take a look at the following MWE and suggest where in the dump or input files my molecule definition is going wrong?
Joe Manning
University of Manchester, UK
Minimum working example
Input file:
# 1) Initialization
units real
atom_style full
pair_style lj/cut 12.5
# 2) System definition
region simulation_box block 0.0 25.832 0.0 25.832 0.0 25.832
create_box 3 simulation_box
# 3) Simulation settings
# Acetonitrile atom type definitions: 1 = C, 2 = Me, 3 = N
mass 1 12
mass 2 17
mass 3 14
pair_coeff 1 1 0.1192 3.55
pair_coeff 1 2 0.1192 3.25
pair_coeff 1 3 0.1524 3.65
pair_coeff 2 2 0.1192 2.95
pair_coeff 2 3 0.1524 3.35
pair_coeff 3 3 0.1947 3.75
# 4) grouping atoms for processing
group gas type 1 2 3
neigh_modify exclude molecule/intra sorb
# 5) outputting dummy data
thermo_style custom step temp etotal
thermo 1
rerun acn_mwe.dump every 1 dump x y z purge yes add yes replace no format native
Dump file:
ITEM: TIMESTEP
0
ITEM: NUMBER OF ATOMS
6
ITEM: BOX BOUNDS pp pp pp
0.0 25.832
0.0 25.832
0.0 25.832
ITEM: ATOMS id type x y z q mol
N 3 15.9568715 23.164098 10.9439578 0.269 1
C 1 14.9471131 23.5570332 10.5382007 0.129 1
Me 2 13.6030958 24.0800411 9.9981265 -0.398 1
N 3 10.1803461 23.3906558 9.1216064 0.269 2
C 1 9.3700299 22.6295461 8.8010619 0.129 2
Me 2 8.291476 21.6164873 8.3744081 -0.398 2
Expected versus actual behaviour
From the thermo
command in the input file, I expect the following to be printed to stdout
Step Temp TotEng
0 0 -0.13326
N.B. This energy value was calculated manually in python
Instead, I get this:
Step Temp TotEng
0 0 1190783.9
System info:
OS: Windows 10
CPU: Intel i7-10750H @ 2.60GHz
LAMMPS version: LAMMPS 64 bit 2 Aug 2023
No MPI version
