Hi @acarnevali,
You should be able to pull what you need with the search method. Any criteria you can provide to the synthesis explorer app, you can also provide to the method. For example, recipes with a precursor of Nb:
with MPRester(api_key=key) as mpr:
docs = mpr.synthesis.search(precursor_formula="Nb")
Below is an example document from the above query to show what is available:
MPDataDoc<SynthesisSearchResultModel>(
doi='10.1016/j.scriptamat.2007.07.038',
paragraph_string='Commercial powders of niobium (99%, -200 mesh), aluminum (99%, -300 mesh) and graphite (99%, -200 ...',
synthesis_type=<SynthesisTypeEnum.solid_state: 'solid-state'>,
reaction_string='1 Al + 1 C + 2 Nb == 1 Nb2AlC',
reaction=ReactionFormula(left_side=[FormulaPart(amount='1', material='Al'), FormulaPart(amount='1', material='C'), FormulaPart(amount='2', material='Nb')], right_side=[FormulaPart(amount='1', material='Nb2AlC')], element_substitution=None),
target=ExtractedMaterial(material_string='Nb2AlC', material_formula='Nb2AlC', material_name='', phase=None, is_acronym=False, composition=[Component(formula='Nb2AlC', amount='1', elements={'Nb': '2', 'Al': '1', 'C': '1'})], amounts_vars={}, elements_vars={}, additives=[], oxygen_deficiency='None'),
targets_formula=['Nb2 Al1 C1'],
targets_formula_s=['Nb2AlC'],
precursors_formula_s=['Al', 'C', 'Nb'],
precursors=[ExtractedMaterial(material_string='Al', material_formula='Al', material_name='', phase=None, is_acronym=False, composition=[Component(formula='Al', amount='1', elements={'Al': '1'})], amounts_vars={}, elements_vars={}, additives=[], oxygen_deficiency='None'), ExtractedMaterial(material_string='C', material_formula='C', material_name='', phase=None, is_acronym=False, composition=[Component(formula='C', amount='1', elements={'C': '1'})], amounts_vars={}, elements_vars={}, additives=[], oxygen_deficiency='None'), ExtractedMaterial(material_string='Nb', material_formula='Nb', material_name='', phase=None, is_acronym=False, composition=[Component(formula='Nb', amount='1', elements={'Nb': '1'})], amounts_vars={}, elements_vars={}, additives=[], oxygen_deficiency='None')],
operations=[Operation(type=<OperationTypeEnum.mixing: 'MixingOperation'>, token='mixed', conditions=Conditions(heating_temperature=[], heating_time=[], heating_atmosphere=[], mixing_device=None, mixing_media='resin')), Operation(type=<OperationTypeEnum.mixing: 'MixingOperation'>, token='milled', conditions=Conditions(heating_temperature=[], heating_time=[Value(min_value=24.0, max_value=24.0, values=[24.0], units='h')], heating_atmosphere=[], mixing_device=None, mixing_media=None)), Operation(type=<OperationTypeEnum.shaping: 'ShapingOperation'>, token='pressed', conditions=Conditions(heating_temperature=[], heating_time=[], heating_atmosphere=[], mixing_device=None, mixing_media=None)), Operation(type=<OperationTypeEnum.heating: 'HeatingOperation'>, token='heated', conditions=Conditions(heating_temperature=[Value(min_value=1600.0, max_value=1600.0, values=[1600.0], units='°C')], heating_time=[], heating_atmosphere=['Ar', 'Ar'], mixing_device=None, mixing_media=None)), Operation(type=<OperationTypeEnum.heating: 'HeatingOperation'>, token='held', conditions=Conditions(heating_temperature=[Value(min_value=1600.0, max_value=1600.0, values=[1600.0], units='°C')], heating_time=[Value(min_value=60.0, max_value=60.0, values=[60.0], units='min')], heating_atmosphere=[], mixing_device=None, mixing_media=None))],
fields_not_requested=['precursors_formula', 'search_score', 'highlights']
– Jason
