I’m trying to run a GCMD simulation. However, when I reach the stage of the simulation where the GCMC fix is initiated, I get an error that the system is not charge neutral:
WARNING: System is not charge neutral, net charge = -0.9999
The system is definitely charge neutral, the total charge of the input data file is ~1e-15. Regular NVT on this system works fine, and I set the charges in the molecule file (oxygen.mol) to be 0. I’m not sure exactly what’s going on. I’ve included some minimal input files for others to take a look. This is everything necessary to run a simulation.
after_anneal.data (1.1 MB)
D2020_1.8_Pt_dreiding.params (7.6 KB)
oxygen.mol (195 Bytes)
run.minimal.in (1.9 KB)
log.lammps (5.6 KB)
