Hi LAMMPS users,
I am interested to model a bond which has anharmonic distribution.
I want to use bond_style table for the same.
Now, to get the table potential, I am following these steps
Inverting the potential as - KB T ln { P® /r^2 }
force = - dU/ dr
But I am not able to get back the initial P®, Instead atoms are moving very far from each other.
What stupid thing, I am unable to figure out… Can anyone help me how to get proper table potentials from the normalized distributions
spandana
sjplimp
#2
I suggest you plot the values you are listing in the bond
table file to insure they are the function you expect. You
could start with something simple like a harmonic bond
to insure you are able to use bond_style table correctly.
Thanks steve,
The energy profiles look much like I wanted them.
Using Xmgrace differences, I calculated the force using forward difference method.
With this style, atoms are moving very far apart.
Still can’t figure out the mistake.
spandana
sjplimp
#4
The author of bond_style table is listed at
the top of the src/bond_table.cpp file with his email.
I suggest sending him an email and seeing if
he has a test problem you can try to verify
it works as you expect.
