Hello LAMMPS users,
I’m trying to run TAD on LAMMPS using the following script:
atom_style atomic
atom_modify map yes
atom_modify sort 0 0.0
newton on
read_data data.interface
pair_style mace no_domain_decomposition
pair_coeff * * MACE-matpes-r2scan-omat-ft.pt-lammps.pt A B C
timestep 0.001
thermo 100
thermo_style custom step temp pe etotal vol press fmax
velocity all create 3000.0 4928459 rot yes dist gaussian
variable interface_z equal 50.5
variable is_inside atom "type == 1 && z < v_interface_z"
fix was_inside all store/state 1 v_is_inside
variable just_entered atom "v_is_inside == 1 && f_was_inside == 0"
compute event all reduce max v_just_entered
fix 1 all nvt temp 3000.0 3000.0 0.1
tad 10000 1 1123 3000 0.01 0.01 event &
min 0.00 0.10 500 500 &
neb 0.00 0.05 2000 2000 20 &
neb_step 0.01 &
neb_log neb.log
dump tad all custom 100 tad.lammpstrj id type x y z```
data.interface consists an interface, and I want to trigger an event every time when atom type 1 enters a specific region (z < z_somevalue). I am getting the following error:
ERROR: Compute does not allow an extra compute or fix to be reset (src/compute.cpp:186)
How can I prevent this error and achieve the same functionality?
(I’m not sure if this error is because tad only works with compute event/displace only.)
Thanks.
