Dear LAMMPS users and developers,
LAMMPS version: 18 April 2015
I am in the process of using pair_style lj/expand for some test simulations. During my tests, I found that the tail corrections for energy and pressure were unreasonably high for WCA like cut-offs. This lead me to read the file pair_lj_expand.cpp . According to the manual (as well as the code), the actual force cut-off is the user provided cut-off (Rc) + the shift factor (Delta). However, this definition of cut-off is not reflected in the tail corrections as coded in init_one().
In particular, I find that line 226 should be: “double shiftcut = - cut[i][j];” instead of: “double shiftcut = shift[i][j] – cut[i][j];” Based on some basic tests, I find that the modified code shows expected behavior.
I have attached the derivation for the tail corrections contribution for the energy term. I believe that the source of the error is that the integration limits were not adjusted during the integration-by-substitution (highlighted). Could you please advise whether there is indeed an error in the pair_lj_expand.cpp or I am missing something? Also, it seems as though pair_lj_expand_omp.cpp inherits init_one() from pair_lj_expand.cpp … so only one line might need to be changed.
Ketan Khare
Rensselaer Polytechnic Institute
Tail correction LJ Expand.pdf (222 KB)
Apologies for resending, sending it as plain text.
In particular, I find that line 226 should be: double shiftcut = -
cut[i][j]; instead of: double shiftcut = shift[i][j] cut[i][j]; Based
so only
Ketan Khare
