I have a tube with its axis in the z direction, and water molecules flowing past the tubes in the x direction. I am trying to measure the tangential force acting on the tube atoms by the water molecules using lammps.
The best way that I have come up with for now is to divide the tube atoms into strips, each strip having atoms with the same x and y coordinates. The atoms in each strip will then be assigned to a group. Then using compute group/group command, I compute the force in the x and y direction acting on each tube strip by the water molecules. Then using post processing, I will resolve the forces into the right tangential direction.
I am wondering if there is an easier way to do this? There will be a problem if I scale up my problem, since lammps limit the number of groups I can define.
Hoping for any advice please. Thanks!
Elisa
