I am computing the temperature of a Poiseuille flow by means of compute temp/profile (in order to substract the spatially-averaged center-of-mass streaming velocity). In the doc page it is explained how the temperature is related to the kinetic energy in this case:
“After the spatially-averaged velocity field has been subtracted from each atom, the temperature is calculated by the formula KE = (dim/2 N - dimNxNy*Nz) k T, where KE = total kinetic energy of the group of atoms (sum of 1/2 m v^2), dim = 2 or 3 = dimensionality of the simulation, N = number of atoms in the group, k = Boltzmann constant, and T = temperature.”
Is it possible that there is a little mistake related to the number of degrees of freedom in the temperature expression? I would say that the right form would be KE = (dimN-dimNxNyNz)*k T/2. That is, the factor (1/2) multiply also the degrees of freedom per bin.
Thanks! And I’m sorry if this point has already been explained.
Carlos Espejo
