Hello LAMMPS users, (version: 7Aug19)
I am comparing the temperature specified as a parameter for fix gcmc to the run average of the temperature calculated using compute_temp. I thought the average would approach the specified temperature, but it does not. The deviation increases with decreasing atom count.
From what I can tell all inserted atoms are assigned velocities from a gaussian distribution corresponding to the specified temperature.
The compute_temp then uses the velocities to compute the temperature by
Ke = 3(N-1)kT, where the -1 is due to the 3 less degrees of freedom from zero linear momentum. I tried to normalize by N instead of N-1 but, there is still deviation.
Should the temperatures not be the same?
Thank you in advance,
Best
Bjorn
Test case:
Control variables
variable MU equal -4.0
variable TEMP equal 2.0
variable TRANS_MAX equal 1.0
variable NTRANS equal 40
variable NEXCH equal 40
variable EQRUN equal 10000
variable PRODRUN equal 40000
variable NEVERY_THERMO equal 1
variable NFREQ_THERMO equal 1000
Setup
pair_style lj/cut 3.0
region box block 0 5 0 5 0 5
create_box 1 box
pair_coeff 1 1 1.0 1.0
mass 1 1.0
group g_gcmc type 1
fix gcmc g_gcmc gcmc 1 {NTRANS} {NEXCH} 1 29494 {TEMP} {MU} ${TRANS_MAX}
run ${EQRUN}
unfix gcmc
reset_timestep 0
variable T equal c_gcmc_temp
variable T2 equal v_T^2
variable T_block2 equal f_block[1]^2
variable T_ave equal f_block_ave[1]
variable T_ave_var equal f_block2_ave[1]-v_T_ave^2
variable T_ave_std equal sqrt((v_T_ave_var>0)*v_T_ave_var)
variable N equal count(g_gcmc)
variable N2 equal v_N^2
variable N_block2 equal f_block[2]^2
variable N_ave equal f_block_ave[2]
variable N_ave_var equal f_block2_ave[2]-v_N_ave^2
variable N_ave_std equal sqrt((v_N_ave_var>0)*v_N_ave_var)
variable trans_accept equal f_gcmc[2]/f_gcmc[1]
variable insert_accept equal f_gcmc[4]/f_gcmc[3]
variable delete_accept equal f_gcmc[6]/f_gcmc[5]
compute gcmc_temp g_gcmc temp
compute_modify gcmc_temp dynamic yes
Averages and error estimates (10 blocks)
fix block all ave/time {NEVERY_THERMO} (v_PRODRUN/10/v_NEVERY_THERMO) (v_PRODRUN/10) v_T v_N fix block_ave all ave/time (v_PRODRUN/10) 10 {PRODRUN} f_block[1] f_block[2] fix block2_ave all ave/time (v_PRODRUN/10) 10 ${PRODRUN} v_T_block2 v_N_block2
thermo_style custom step v_T v_N
thermo ${NFREQ_THERMO}
run ${PRODRUN}
print “-----------------------------------------”
print “Run Summary”
print “N_ave: {N_ave} +- {N_ave_std}”
print “T_ave: {T_ave} +- {T_ave_std}”
print “trans_accept: {trans_accept}"
print "insert_accept: {insert_accept}”
print “delete_accept: ${delete_accept}”
