I saw some simulation where they used following command
Units lj
velocity all create .32 4928459
They used temperature here in lj units (.32). How to convert it in Kelvin.
You can’t, because the unit conversion depends on what element is being studied. All that matters for thermodynamics is the ratio E/kT, at which point it doesn’t matter what units E and T are for as long as they are consistent.
I am using E and K in units of KJ/mol. what will be the units of T in E/kT
