Hi, Lammps users,
I am trying to use the qeq method implemented in lammps after reading Rappa, and Rick work, i first tried the qeq/point with chi and J from Rappa’s work, a 100 ps NVT run followed by 200 ps NVE run where i dumped the trajectory. But the resulting temperature went a progressive increase. I checked the animation of the trajectory, no abnormal things happened. Then i tried qeq/dynamic and qeq/slater, again, the temperature is progressively increase. i have copy the lammps input file, and the para.qeq file, and the log file, any help about what the possible reason could be and what to track down are appreciated.
Best Regards
Jiasen Guo
1 4.168 6.974 0 0.38685 0.001
2 8.741 13.364 0 0.48725 0.001
lammps input script for Sodalite with MZHB
atom_style full
read_data MZHB_SOD_original.lmp
potential
bond_style harmonic
bond_coeff 1 11.650000 1.6200000
angle_style harmonic
angle_coeff 1 3.4000000 109.47000
angle_coeff 2 1.1100000 149.80000
pair_style lj/cut/coul/long 12.000
pair_coeff 1 1 0.0085997000 1.959982864 12.0000
pair_coeff 1 2 0.0052661900 1.758034219 12.0000
pair_coeff 2 2 0.0032249000 1.576892023 12.0000
special_bonds lj 1.0 1.0 1.0 coul 1.0 1.0 1.0
kspace_style ewald 1.0e-12
in.MZHB_SOD_md (1.79 KB)
para.qeq (62 Bytes)
qeq.log (309 KB)
