I’m currently trying to simulate a group of particles called active particles. This system is basically a bunch of particles with each having their own propulsion( the direction, propulsion are determined by certain simple rules). Hence, the energy of the system is not conserved (in the conventional sense ke+pe). But I would expect a uniform variation in temp, ke, pe and etotal. I have made the following changes in the code and the temp&ke seem to be fluctuating too rapidly. I have realized that this could be a problem as the system im trying to simulate doesn’t seem to evolve very appreciably over large time scales as the systems (well documented, see below.) have done. And these changes run perfectly for the documented systems as below.
I have attached below the changes made in the file of changes being made and log.lammps.
What might cause this?
For more info please consult these two papers:
- [http://dx.doi.org/10.1119/1.4870398] Simulation of the active Brownian motion of a microswimmer.
- [DOI: 10.1039/c3sm52813h] Phase behavior of active Brownian particles: the
role of dimensionality. (In my system I’m trying to put the particles which follow equations 6 & 7)
changes.txt (4.64 KB)
log.lammps (44 KB)
