So, I have done certain modifications so that the script calculates the temperature of a group of atoms, after subtracting out the center-of-mass velocity of the group using “temp/com” . the compute statement works but it shows an error in the statement where I am trying to save this temperature in a file called temp.${vpis} . the error is " Fix ave/chunk compute does not calculate per-atom values" .The modified script is :
---------- Initialize Simulation ---------------------
clear
atom_style atomic
atom_modify map array
variable a loop 9
---------- define variables ---------------------
variable Ts equal 300
variable alat equal 3.304
variable myseed equal 12345
variable xm equal 10
variable ym equal 10
variable zm equal 420 #LJ
variable dt equal 0.001
variable t_eq equal 10000
variable t_sh equal 50000
variable vpis index 0.1 0.3 0.5 1.0 1.3 1.8 2.2 2.5 3
variable Nevery equal 10
variable Nrepeat equal 5
variable Nfreq equal 500
variable dz equal 10
variable atomrate equal 5000
variable tdamp equal “v_dt100"
variable pdamp equal "v_dt1000”
variable Up equal “10*v_vpis”
timestep ${dt}
---------- Create Atoms ---------------------
lattice bcc ${alat} origin 0.0 0.0 0.0 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
#tmd 27g/NA 6e23 *4 atoms/cell/(4.05e-8cm)3 = 2.7 g/cm3
define size of the simulation box
region sim_box block 0 {xm} 0 {ym} 0 ${zm} units lattice
create_box 2 sim_box
define atoms in sim_box
region atom_box block 0 {xm} 0 {ym} 0 ${zm}
create_atoms 1 region atom_box
define a group for the atom_box region
group atom_box region atom_box
region piston block INF INF INF INF INF 4
region bulk block INF INF INF INF 4 INF
group piston region piston
group bulk region bulk
set group piston type 1
set group bulk type 2
---------- Define Interatomic Potential ---------------------
for lj, epsilon (eV) = heat of sublimation/atom
for lj, sigma (ang)= 2**(-1/6)*nearest neighbour distance
epsilon is 3.34 eV (cohesive energy per atom from Avinc)
sigma is 2**(-1/6) * (4.052+4.052)**.5 /2 angstrom == 2.55 Angstrom * 2.5 == 6.38
mass 1 180.95
mass 2 180.95
#pair_style lj/cut 6.38
#pair_coeff * * 3.34 2.55
pair_style eam/alloy
pair_coeff * * Ta.eam.alloy Ta Ta
pair_style eam/fs
pair_coeff * * al1.eam.fs Al Al
pair_coeff * * Al99.eam.alloy Al Al
#mass 1 180.95
#mass 2 180.95
compute myCN bulk cna/atom 3.0
compute myKE bulk ke/atom
compute myPE bulk pe/atom
compute myCOM bulk com
compute peratom bulk stress/atom NULL
compute vz bulk property/atom vz
compute vorvol bulk voronoi/atom
compute tempcomm bulk temp/com
------------ Equilibrate ---------------------------------------
reset_timestep 0
Now, assign the initial velocities using Maxwell-Boltzmann distribution
velocity atom_box create {Ts} {myseed} rot yes dist gaussian
fix equilibration bulk npt temp {Ts} {Ts} {tdamp} iso 0 0 {pdamp} drag 1
variable eq1 equal “step”
variable eq2 equal “pxx/10000”
variable eq3 equal “pyy/10000”
variable eq4 equal “pzz/10000”
variable eq5 equal “lx”
variable eq6 equal “ly”
variable eq7 equal “lz”
variable eq8 equal “temp”
variable eq9 equal “etotal”
variable eq11 equal “density”
fix output1 bulk print 10 “{eq1} {eq2} {eq3} {eq4} {eq5} {eq6} &
{eq7} {eq8} {eq9} {eq11}” file run.out.${vpis} screen no
thermo 10
thermo_style custom step pxx pyy pzz lx ly lz temp etotal density
run ${t_eq}
unfix equilibration
unfix output1
-------------- Shock -------------------------------------------
change_box all boundary p p s
reset_timestep 0
WE CREATE A PISTON USING A FEW LAYERS OF ATOMS AND THEN WE GIVE IT
A CONSTANT POSTIVE SPEED. YOU COULD ALSO USE LAMMPS’ FIX WALL/PISTON COMMAND
fix 1 all nve
velocity piston set 0 0 v_Up sum no units box
fix 2 piston setforce 0.0 0.0 0.0
WE CREATE BINS IN ORDER TO TRACK THE PASSING OF THE SHOCKWAVE
compute 3 bulk chunk/atom bin/1d z lower ${dz} units box
fix density_profile bulk ave/chunk {Nevery} {Nrepeat} {Nfreq} 3 density/mass file denz.{vpis}
fix temp_profile bulk ave/chunk {Nevery} {Nrepeat} {Nfreq} 3 c_tempcomm file temp.{vpis}
meanpress was originally pressure *volume per atom (cubic distance units)
manual suggests use compute voronoi/atom to estimate atomic volume
variable meanpress atom -(c_peratom[1]+c_peratom[2]+c_peratom[3])/3/(c_vorvol[1]+1e-99)
fix pressure_profile bulk ave/chunk {Nevery} {Nrepeat} {Nfreq} 3 v_meanpress file pressure.{vpis}
fix velZ_profile bulk ave/chunk {Nevery} {Nrepeat} {Nfreq} 3 c_vz file velocityZcomp.{vpis}
variable eq10 equal “c_myCOM[3]”
fix shock bulk print 10 "{eq1} {eq2} {eq3} {eq4} {eq5} {eq6} {eq7} {eq8} {eq9} {eq10} {eq11}" file run.{Ts}K.${vpis} screen no
thermo 10
thermo_style custom step pxx pyy pzz lx ly lz temp etotal c_myCOM[3] density
#Use cfg(?) for AtomEye
dump 1 all cfg {atomrate} dump._*.{vpis}.cfg mass type xs ys zs id c_myPE c_myKE c_myCN
dump_modify 1 element Ta Ta
#dump 2 all image 1000 image.*.jpg type type axes yes 0.8 0.02 view 120 -90
run ${t_sh}
clear
next vpis
next a
jump Tashock.in
