I am trying to simulate adsorption of water on graphitic carbon nitride.
For the carbon nitride without water I draw the graphitic structure and I use it as initial geometry with tersoff potential and it is stable.
For water without carbon nitride I use SPC potential and it is stable.
To combine both, I wish to use Lennard-Jones potential between carbon nitride and water. I plan to optimize the LJ-parameters but to start I simply use the oxygen parameters for all cross interactions.
The issue is that the crystal is not stable when I add the hybrid interaction. I tried several ways to initializing the system, i.e first minimizing energy and then adding temperature or similar.
I appreciate hints with regards to conceptual or technical mistakes.
Below are my settings for the hybrid potential
setting
atom_style full
units real
pair_style hybrid lj/charmm/coul/long 9.0 11.0 tersoff
bond_style harmonic
angle_style harmonic
pair_modify mix geometric
special_bonds lj/coul 0.0 0.0 0.5
kspace_style pppm 0.0001
water
bond_coeff 1 450.00 1.000
angle_coeff 1 55.00 109.47
pair_coeff 2 2 lj/charmm/coul/long 0.0 0.0
pair_coeff 4 4 lj/charmm/coul/long 0.1553 3.166
carbon nitride
pair_coeff * * tersoff cn.tersoff C NULL N NULL
cross-terms
pair_coeff 1 2 lj/charmm/coul/long 0.1553 3.166
pair_coeff 1 4 lj/charmm/coul/long 0.1553 3.166
pair_coeff 3 2 lj/charmm/coul/long 0.1553 3.166
pair_coeff 3 4 lj/charmm/coul/long 0.1553 3.166
