Dear Anders,
Many thanks for your reply.
I did the simulation for a smaller box. I have attached the potential functions. You can find the script in the following.
You can see that while using vashishta potential, atoms start flying, however, for the Erhart potential, the simulation is fine.
newton on
atom_style atomic
lattice diamond 4.3613 origin 0 0 0 orient x 0 1 0 orient y 0 0 1 orient z 1 0 0
region box1 block -0.2 20.2 -0.2 20.2 -0.2 20.2
region box2 block 0 20 0 20 0 20
create_box 2 box1
create_atoms 2 region box2 basis 1 1 basis 2 1 basis 3 1 basis 4 1 basis 5 2 basis 6 2 basis 7 2 basis 8 2
group box2 region box2
pair_style vashishta
pair_coeff * * SiC.vashishta Si C
#pair_style tersoff
#pair_coeff * * SiC_Erhart-Albe.tersoff Si C
neighbor 5.0 nsq
neigh_modify every 2 delay 10 check yes cluster yes binsize 5
mass 1 28.0855
mass 2 12.0107
min_style sd
minimize 2.5e-6 1.0e-6 100000 100000
velocity box2 create 300 900000
fix 1 all nve
fix 2 box2 temp/rescale 100 300 300 2 1
fix_modify 2 energy yes
thermo 1000
thermo_style custom step temp pe ke etotal
timestep 0.001
run 5000
unfix 2
thermo 100
dump 1 all atom 100 dump.Equilib*.lammpstrj
dump_modify 1 scale no
run 200
SiC.vashishta (1.54 KB)
SiC_Erhart-Albe.tersoff (1.6 KB)
