Dear Lammps users,
I write my own pair potentials and I want to check if the equation is corrected coded in the potential files, so at first I need to find a good checking method.
Take morse potential for example,
,and I set D0=19.7866, alpha=2.0579 and r0=2.4200 for Mg, then I minimize the energy of the system for different initial lattice constant at 0K, and output lattice constant a and per-atom potential energy P, the comparison is like this:
I find out that they differ much. Is my method reasonable? or how can I do the simulation to get the second line so as to check my own potential code?
Any help will be appreciated, thank you so much.
Michelle
Dear Lammps users,
checking method.
Take morse potential for example, ,and I set D0=19.7866, alpha=2.0579 and
code?
the simplest test is to use the "pair_write" command and then plot the
potential and force as written out and compare to your formula. however,
that tests only the Pair::single() API and not Pair::compute()
for the latter, you could do a series of calculations with two atoms that
you place at different distances with a loop and then compute the energy
and force via "run 0".
this kind of topic has come up recently in the mailing list. please check
out https://sourceforge.net/p/lammps/mailman/message/34925329/ . the
specific testing example comes up somewhere in the middle of the thread.
