Perhaps I wasn’t clear enough…
If you python test.py with test.py containing the following:
Enter code here…from fireworks.core.firework import Firework, Workflow
from fireworks.core.fworker import FWorker
from fireworks.core.launchpad import LaunchPad
from fireworks.core.rocket_launcher import launch_rocket, rapidfire
from fireworks.user_objects.firetasks.script_task import ScriptTask
def setup():
launchpad = LaunchPad(name='fireworks_test')
#launchpad.reset()
return launchpad
def basic_wf_ex():
print('--- BASIC WORKFLOW EXAMPLE ---')
# setup
launchpad = setup()
# add FireWorks
task1 = ScriptTask.from_str('echo "Ingrid is the CEO."')
task2 = ScriptTask.from_str('echo "Jill is a manager."')
task3 = ScriptTask.from_str('echo "Jack is a manager."')
task4 = ScriptTask.from_str('echo "Kip is an intern."')
fw1 = Firework(task1, fw_id=1)
fw2 = Firework(task2, fw_id=2)
fw3 = Firework(task3, fw_id=3)
fw4 = Firework(task4, fw_id=4)
# make workflow
workflow = Workflow([fw1, fw2, fw3, fw4], {1: [2, 3], 2: [4], 3: [4]})
launchpad.add_wf(workflow)
# launch Rocket
rapidfire(launchpad, FWorker())
if ‘main’== name:
basic_wf_ex()
Which is a small subset of the example in test.py, you may then not be able to see any fireworks if you try the lpad in the commandline / terminal. This also translate to not seeing any completed jobs in the webgui. Is there something I am missing here?
On Monday, November 26, 2018 at 4:36:12 PM UTC+1, ajain wrote:
Hi
The webgui can currently only be used to monitor the progress of workflow and jobs. It cannot be used to compose or submit workflows as we have not built a UI to do so. To submit a workflow, you’d either need to use the command line or Python interface.
On Mon, Nov 26, 2018 at 4:04 AM Christopher Pashartis [email protected] wrote:
I’m curious as to how the webgui syncs with the launches using the python method to submit tasks. It would seem that if you want to use the webgui you are forced to submit jobs via commandline / terminal. Maybe I’ve missed something in the tutorial, but an explanation would be appreciated.
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
For more options, visit https://groups.google.com/d/optout.
Anubhav
