Hello all,
I am performing a heating-quenching method to stabilize the temperature of my silicon supercell. I increase the temperature from 1K to 400K and then cool it down from 400K to 100K, which is my target final temperature. I conduct the heating and cooling in steps of approximately 30K using NVT. Between each step, I also use NVT at the same temperature to stabilize the system before proceeding to the next step. The problem is that after about 100ps the silicon becomes amorphous instead of maintaining its diamond structure.
I have also tried using NPT for this method, but I encounter the same issue. My goal is to ensure that the final velocities of the silicon atoms are representative of their actual movement, which is why I am employing this heating-quenching approach.
How can I achieve this objective without losing the crystallinity of silicon?
