the issue of the simulation of rigid methane molecules in LAMMPS
Hi, ALL
I am trying to run simulations of a system involving rigid methane molecules. However,
it seems that SHAKE in LAMMPS can not handle methane because the carbon is connected
to 4 hydrogen atoms. In the manual, it mentions that
“LAMMPS allows for the following kinds of clusters to be constrained: one central atom
bonded to 1 or 2 or 3 atoms, or one central atom bonded to 2 others and the angle between
the 3 atoms also constrained.”
BTW, to ensure the rigidity of the methane molecule, I defined 9 distances for methane, i.e.
4 C-H bond, and 5 H-H bond.
Is there anyway to circumvent this issue ? Thanks.
Guozhen
Hi, ALL
molecules. However,
connected
"LAMMPS allows for the following kinds of clusters to be constrained: one
central atom
angle between
the 3 atoms also constrained."
Is there anyway to circumvent this issue ? Thanks\.
there are three options:
- implement a version of SHAKE that allows more complicated
  constraints (at the expense of parallel efficiency).
- use one of the "rigid" integrators instead,
  those will integrate the translational and
  rotational degrees of freedom separately.
- use a united atom model. that is often a
  reasonable approximation, since methane
  is almost spherical.
Hi, ALL
molecules. However,
connected
central atom
angle between
  • implement a version of SHAKE that allows more complicated
  • use one of the “rigid” integrators instead,
How to use this option ? Thanks.
http://lammps.sandia.gov/doc/fix_rigid.html
make sure to start with a small enough timestep,
the integration of rotational d.o.f.s is more
more fragile than the integration of the c.o.m.
a.
Hi, ALL
molecules. However,
is
connected
one
central atom
the
angle between
Thanks a lot !
One more question. What if I want to apply NPT to the system ?
then you have to program it. the paper describing
the rigid/nvt integrator also describes a rigid/npt
integrator, but it has not (yet) been implemented
and i am not sure if the author of rigid/nvt is still
working on it.
Is it reasonable to apply a very stiff bond potential on the methane molecule to mimic the rigidity ?
why not use the proper potentials for bonded interactions, then?
