Dear FireWorks developers and community,
I’d like to store the entire standard error in the Firework Launch object’s stored_data. Here is my Firetask:
ft_vasp=ScriptTask.from_str(f"touch ./vasp.out;{vasp_code} ",\
{"stdout_file":"./vasp.out" , "store_stderr":True})
The vasp running will report an error because I did not provide POSCAR. When I launch it, the output is correctly written to the vasp.out, however, lpad get_fws shows the stored_data contains only _stacktrace but no error reporting information:
"stored_data": {
"_message": "runtime error during task",
"_task": {
"stdout_file": "vasp.out",
"store_stderr": true,
"script": [
"touch ./vasp.error;touch ./vasp.out;module load mkl/latest\nmodule load mpi/latest\nmpirun /share/apps/vasp-cpu/bin/vasp_std "
"use_shell": true,
"_fw_name": "ScriptTask"
"_exception": {
"_stacktrace": "Traceback (most recent call last):\n File \"/share/home/prome/anaconda3/envs/prome_20230306/lib/python3.9/site-packages/fireworks/core/rocket.py\", line 261, in run\n m_action = t.run_task(my_spec)\n File \"/share/home/prome/anaconda3/envs/prome_20230306/lib/python3.9/site-packages/fireworks/user_objects/firetasks/script_task.py\", line 38, in run_task\n return self._run_task_internal(fw_spec, stdin)\n File \"/share/home/prome/anaconda3/envs/prome_20230306/lib/python3.9/site-packages/fireworks/user_objects/firetasks/script_task.py\", line 90, in _run_task_internal\n raise RuntimeError(f\"ScriptTask fizzled! Return code: {returncodes}\")\nRuntimeError: ScriptTask fizzled! Return code: [24]\n",
"_details": null
Could you please give me some advice? I would greatly appreciate any help or examples you could provide.
Thank you very much,
wed
