Dear all
I installed the LAMMPS-18Dec2018 and successfully added the GPU package. When I run the script with GPU, it is OK.
However, today I install the LAMMPS-29Sep2021 and successfully add the GPU package.
but when I run the script with GPU, There is an error.
Could anybody help me to check the problem?
>>/home/dell/Softrun/cp2k-8.2.0/tools/toolchain/install/openmpi-4.0.5/bin/mpirun -np 8 /home/dell/Softrun/lammps-29Sep2021/src/lmp_mpi -sf gpu -pk gpu 8 < in.deposit.molecule
LAMMPS (29 Sep 2021 - Update 1)
- UCL Error: Error compiling PTX Program…*
*[dell-PowerEdge-T630:54598] *** Process received signal ****
[dell-PowerEdge-T630:54598] Signal: Segmentation fault (11)
[dell-PowerEdge-T630:54598] Signal code: Address not mapped (1)
[dell-PowerEdge-T630:54598] Failing at address: (nil)
The all error information is attached.
Yanyan
error.txt (16.5 KB)
