Dear Sir/Madam…
I am tried to calculate the Thermal Conductivity of Diamond at 300 K.
But in journals, it saying that Diamond having very high values of Thermal conductivity and at 300K its about 2000W/(mK).
But in my calculation, i m getting the value of Thermal Conductivity less than 100 W/(mK)…
I am giving the detailed input script of my Calculation.
Can U give me any suggestion of this mismatching between Theory, Experiment & Simulation.
Sample LAMMPS input script for thermal conductivity of Diamond
variable T equal 300
variable V equal vol
variable dt equal 0.001
variable p equal 100 # correlation length
variable s equal 10 # sample interval
variable d equal $p*$s # dump interval
convert from LAMMPS metal units to SI
variable kB equal 1.3806504e-23
variable eV2J equal 1.602177e-19
variable A2m equal 1.0e-10
variable ps2s equal 1.0e-12
variable convert equal {eV2J}*{eV2J}/{ps2s}/{A2m}
setup problem
lattice diamond 3.5626 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region box block 0 5 0 5 0 5
create_box 1 box
create_atoms 1 box
mass 1 12.0107
pair_style tersoff
pair_coeff * * SiC.tersoff C
timestep ${dt}
thermo $d
equilibration and thermalization
velocity all create $T 102486 mom yes rot yes dist gaussian
fix NVT all nvt temp $T $T 10 drag 0.2
run 8000
thermal conductivity calculation, switch to NVE if desired
#unfix NVT
#fix NVE all nve
reset_timestep 0
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all stress/atom virial
compute flux all heat/flux myKE myPE myStress
variable Jx equal c_flux[1]/vol
variable Jy equal c_flux[2]/vol
variable Jz equal c_flux[3]/vol
fix JJ all ave/correlate $s $p d &
c_flux[1] c_flux[2] c_flux[3] type auto file J0Jt.dat ave running
variable scale equal {convert}/${kB}/$T/$T/$V*s*
{dt}
variable k11 equal trap(f_JJ[3]){scale}
variable k22 equal trap(f_JJ[4])*{scale}
variable k33 equal trap(f_JJ[5])${scale}
thermo_style custom step temp v_Jx v_Jy v_Jz v_k11 v_k22 v_k33
run 100000
variable k equal (v_k11+v_k22+v_k33)/3.0
variable ndens equal count(all)/vol
print “average conductivity: $k[W/mK] @ T K, {ndens} /A^3”
Hoping forward for your reply
Many Thanks & Kind Regards
Siby
