Dear Dr. Alex
Thank you so much for your help and also for your quick response.
I simulate the buckling of CNT under the radial pressure through displace atoms in middle section of tube (group 1) with fixed boundary conditions at the two ends of CNT (group 2 &3 with five and eight raw of atoms at two ends of CNT), as below:
label looplable
displace_atoms 2 move 0 0 0 units box
displace_atoms 3 move 0 0 0 units box
displace_atoms 1 move v_x2 v_y2 0 units box
fix 2 1 nvt temp 300 300 0.01
thermo_style custom step temp vol pe press v_y1 v_x1
run 5000
next Nstep
jump in.cnt looplable
(Note that there are 2208 atoms in this simulation of CNT which 1896 atoms are in group 1 and 120 and 192 residual atoms are in group 2 &3)
I dont know which section of CNT should be considered to impose nvt command on its atoms. When I impose nvt on middle section of CNT (group1), as:
the buckling does not take place because through nvt command the pressure is removed.
Please help me.
Thank you.
