Thermostatting During Uniaxial Tension Simulation with Internal Crack and Velocity Bias
I’m running a uniaxial tension simulation in LAMMPS where the sample contains an internal crack (created by deleting atoms). I’ve divided the system into three groups:
  1. Mobile group: This is the main deforming region, which includes the crack. I applied a velocity ramp in the y-direction to this group.
  2. Lower boundary group: This group is fixed in space.
  3. Upper boundary group: This group is given a constant velocity in the y-direction to apply the tension.
I’m using fix nvt to maintain temperature in the mobile group. Since I’m applying a velocity ramp, I learned that I should use compute temp/ramp and then apply fix_modify to avoid including the bias in the temperature calculation.
My main question is:
  • Should I apply any thermostat (like fix nvt) to the upper and lower boundary groups?
I’m currently assuming that only the mobile group should be thermostat-controlled, and the upper/lower boundaries should either be fixed or moved without temperature control.
Any clarification or best practices would be appreciated. Thanks in advance!
I don’t think there is a right answer to that question, and if there is, this forum is probably not the best place to obtain it.
Also, when I read the question:
I wonder if you are asking whether you should apply a Nose-Hoover thermostat, or if you’re asking whether to integrate the equations of motion at all (versus leaving the atoms as a frozen block). But regardless, these choices can only be seriously answered by you, an expert, or a tutor.
Simon
