Hello Everyone,
I wanted to know the procedure of starting up a water vapor calculation in LAMMPS. I want to calculate properties of water vapor at a higher temperature than 100 Celsius. Currently I am setting up the simulation same as liquid water but with the density of 0.001gm/cm3. So, initially my box has 1000 times less molecules than that of liquid water and it has 800 atoms in 200x200x200 A3 box. The simulation runs perfectly till 267 K but after that simulation stops mid-way giving me errors.
I would appreciate if anybody can help me.
Rahul
INPUT SCRIPT
clear
units real
atom_style full
read_restart 374K40box.1Bar.restart.150000
create groups
group ox type 3
group hy type 1 2
set charges - beside manually
set group ox charge -0.830
set group hy charge 0.415
TIP3P Potential Parameters
pair_style lj/cut/coul/long 10.0
pair_coeff 1 1*2 0.000 0.000
pair_coeff 1 3 0.000 0.000
pair_coeff 2 2 0.000 0.000
pair_coeff 2 3 0.000 0.000
pair_coeff 3 3 0.102 3.188
bond_style harmonic
bond_coeff 1 1050 0.9572
angle_style harmonic
angle_coeff 1 550 104.52
kspace_style pppm 1.0e-5 #final npt relaxation
fix 1 all shake 1e-6 200 0 b 1 a 1
velocity all create 1.0 1234546 dist gaussian
fix 2 all npt temp 374.0 374.0 100.0 iso 1.0 1.0 1000.0
#Compute RDF and save to file
This will compute rdf between oxygen-oxygen, oxygen-hydrogen, and hydrogen-hydrogen
compute myRDF all rdf 500 1 1 1 2 2 2
fix 3 all ave/time 2 100 5000 c_myRDF file tip3p_afterboiling40.rdf mode vector
neighbor 10.0 bin
neigh_modify delay 10 every 2 check yes page 100000
thermo 100
thermo_style custom step temp press vol ke pe etotal enthalpy
thermo_modify norm no flush yes
#dumps
dump 1 all custom 1000 traj_npt_after373.lammpstrj id mol type x y z ix iy iz
restart 50000 374K40box.1Bar.restart
#run variables
timestep 0.0001
run 60000000
