Hi everyone,
I am trying to simulate a system that consists of water in a catalyst pore. My catalyst slab with adsorbate is frozen with free water molecules (TIP4P/2005) on top. I tried with 2 different versions of dlpoly (4.03.4 & 4.09) and I face the following issues-
- In version 4.09, the simulation runs okay with rigid body TIP4P/2005 water molecules but the total energies are diverging (shoots up). I ran the simulation for 5 nanoseconds and the energy still doesn’t converge. Later I tried to use the constrained body dynamics instead of treating water as rigid body, but that shows error message 644, i.e., the system is over constrained.
- In version 4.03.4, using the same water model, I get the error message 642 that says rigid body unit diameter is greater than system cutoff. I was using a 12 Å cutoff, so I increased that up to 22 Å, but it shows the same error message. I can’t increase it further due to my system size.
The following is how I define water molecules as rigid body in the FIELD file,
nummols 641
atoms 4
Ow 16.0000 0.0000
Hw 1.0000 0.5564
Hw 1.0000 0.5564
Om 0.0000 -1.1128
rigid 1
4 1 2 3 4
finish
I have previously simulated TIP3P water with constraints in similar scenario without any issue.
Can you please share your experience about working with TIP4P water in dlpoly? Thank you so much!
To unsubscribe from the DLPOLY list, click the following link:
https://www.jiscmail.ac.uk/cgi-bin/WA-JISC.exe?SUBED1=DLPOLY&A=1
