TIP4P-FQ
Dear Sir:
I would like to know if lammps can build TIP4P-FQ water molecular model? which commands can help me build TIP4P-FQ water molecular model? I now understand only pair_style lj / cut / tip4p / long, fix qeq / dynamic.
Sincerely,
Gang Liu
Dear Sir:
​i don't understand what you are asking here or whether you are answering
your own question and want approval for it.
what is required to model TIP4P-FQ should be explained in the
​publication(s) describing it. then you need to compare what is written
with the LAMMPS manual and make certain, that the LAMMPS features you
choose match. nobody will do that for you.
