Greetings,
I have a system of tip4p water + uam methane molecules. This is a unit-cell for s1 methane motif. I create the initial simulation box using the replicate command.
Then I try to minimize the energy of the system but I face the error below:
ERROR on proc 5: TIP4P hydrogen has incorrect atom type (src/KSPACE/pair_lj_cut_tip4p_long.cpp:226)
Last command: minimize 1.0e-6 1.0e-8 1000000 4000000
ERROR on proc 6: TIP4P hydrogen has incorrect atom type (src/KSPACE/pair_lj_cut_tip4p_long.cpp:226)
As per checking the forcefield information, I am using the correct otype and htype as:
pair_style lj/cut/tip4p/long 2 3 1 1 0.1577 20.0
I changed the cut-off to a big number as you see above, but it did not change anything. Also neighboring list is updated at every time-step.
I am using the following version of lammps:
LAMMPS (23 Jun 2022)
Also, I use periodic boundary conditions but some of the atoms in the original s1 unit-cell fall outside the box. Could have this caused the issue?
