When trying to equilibrate a mixed tip4p/2005 water and SO2 system, I got the error:
ERROR on proc 0: TIP4P hydrogen has incorrect atom type (…/pair_lj_cut_tip4p_long.cpp:224)
While this looks like an obvious mistake in data file, I could not identify it. I tried to print the jtype, type[jH1], type[jH2] before the error occurs. It shows that jtype and type[jH1] is H, and type[jH2] is O. I cannot understand why.
Attached is my input and data files. I am using version 1Feb14. Can you provide some ideas on this? Thanks!
the error:
(../pair_lj_cut_tip4p_long.cpp:224)
understand why.
so you have otype=2 htype=2 btype=1 atype=1. so you assign O and H to
the same type. that is definitely wrong and *very* obvious.
furthermore, there is no reason to use a hybrid pair style for this
kind of system. lj/cut/tip4p/long acts as lj/cut/coul/long for all
types that are not flagged as otype or htype.
