Dear LAMMPS users,
I have a question concerned with the TIP4P water model. I wonder why
the total energy in NVE simulation with TIP4P water model is not
conserved. When I did NVE simulation with TIP4P water model (12A for
L-J cutoff and 8.5A for Coulombic cutoff), the total energy was not
conserved. In stead, the kinetic energy (temperature) kept increasing.
I have used " kspace_style pppm/tip4p 10e-4", if I want to use ewald
summation in this model, can I use? how to? I think there is no option
for kspace_style.
Attached are the input script, data file and temperature file for the
TIP4P water model. Thanks.
Regards,
Farrokh
in.txt (1.32 KB)
solvate.data (143 KB)
temp.txt (3.36 KB)
the pppm with the default ik differentiation cannot conserve energy.
To have a better energy conservation, you could try to use the
kspace_modify ad
command. If you want to use Ewald summation, you will have to implement
an ewald/tip4p style, similar to the pppm/tip4p.
Rolf
Dear LAMMPS users,
with a long-range solver, there is no benefit to reduce the coulomb
cutoff below the LJ cutoff. most of the computational effort lies in
looking up the coordinate data, so if you have this done for LJ
already, adding the real space for coulomb comes at little extra cost
(hence the combined pair style instead of using hybrid/overlay).
your energy conservation should be much improved with using pppm/tip4p 1.e-5
no need to use that small a time step, either. when using shake. 1fs
would be a very conservative choice already.
for kspace_style.
energy conservation doesn't look too bad actually, if you discard the
first chunk. your system apparently wan't fully equilibrated.
Thanks Dear Rolf and Axel.
Farrokh
