To solve the error: "TypeError: 'CompoundPhaseDiagram' object is not iterable"
Dear Maintainers & Developers,
It’s my first time to use pymatgen, when I use the command of ‘CompoundPhaseDiagram’, the error listed below occurred, how to solve this ‘TypeError’? Can you give me some suggestions?
CompoundPhaseDiagram is itself a PhaseDiagram, i.e. it is a child class of PhaseDiagram. You do not need to initialize it by passing pd to PhaseDiagram. The PhaseDiagram constructor takes a list of entries as input, which is the thing it is trying to iterate in the error message, but it finds your object pd instead.
:wave:thanks for replying, Iet me have a try.
Dear Mr.Nicholas,
I have the typeError: ‘PhaseDiagram’ object is not iterable,
I was try your suggestion, but it sill error,
So can you instruct to me for slove this problem with other way?
Thank for your helping,
Dear @buithitham
ChempotDiagram requires “entries” to work.
In your case, it looks like you put in a PhaseDiagram.
Refer this code:
from pymatgen.entries.computed_entries import GibbsComputedStructureEntry
from rxn_network.thermo.chempot_diagram import ChempotDiagram
with MPRester('xxxx') as mpr:
    entries = mpr.get_entries_in_chemsys("Li-Co-O")
entries_RT = GibbsComputedStructureEntry.from_entries(entries, 300)
cpd_from_rxn = ChempotDiagram(entries_RT)
cpd_from_rxn.get_plot()
You can get this ChempotDiagram
Dear Mr.Kim,
I was solve my problems,
Thank for your hepling!
Hi @buithitham,
Glad you were able to get it fixed! Note that your issue differs from the original issue in this post (which was about CompoundPhaseDiagram).
I also wanted to give a heads-up that you are importing ChempotDiagram from the rxn_network package, but the class ChempotDiagram only exists to add features I wanted to include in the analysis of reaction networks.
So to avoid future confusion and more dependencies, you should probably import it as follows:
from pymatgen.analysis.chempot_diagram import ChemicalPotentialDiagram
Dear Mr.mattmcdermott
Thank you so much for helping!
Hi all,
when i use ComputedStructureEntry and GibbsComputedStructureEntry to predicate the free enegy, the error is shown in this figure, Could you give me some suggestions?
