Axel,
When creating xyz coordinate files from crystallographic data using multiple of lattice parameters (a, b,c) and alpha=beta=gamma = 90 topotool is quite useful for getting a LAMMPS input file, but I have been having problems with the bounding box values xlo, xhi, ylo, yhi , zlo and zhi.
I ran the following on VMD Tkconsole
% pbc set {12.2916 21.0939 29.9379 90.0 90.0 90.0}
% topo writelammpsdata input.coord full
I got the right input.coord file, but topotool listed the serial numbering twice (see data below)
I had to manipulate the file to remove unwanted columns before I could run LAMMPS. I was getting an error that reads
"Incorrect atom format in data file"
These are my questions;
(1) How can I exclude bonds, angles, dihedral and improper types when using the full command
(2) Why am I getting double serial numbering in the LAMMPS file which is the cause of the error.
How can I eliminate this without resorting to modifying the output file every time. Is it possible that
I am using an old version of topotool that comes with VMD?
(3) The bounding box values xlo, xhi, ylo ... doesn't seems to give me the correct energy and structure
as the simulation always result into loss of atoms or giving Nan energies. I already check the xyz file on VMD and xmakemol
and all atoms have the correct bond length and angles. CrystalMaker shows all bonds are greater than 2.4 Angstroms. The box
axes are orthogonal , but not cubic. Must the box be cubic?
(4) Are you doing any work on topotool for triclinic box with non-orthogonal axes?
Your help would be appreciated.
Suleiman.
LAMMPS data file. CGCMM style. generated by VMD/TopoTools v1.0 on Thu Mar 31 11:08:26 CDT 2011
676 atoms
0 bonds
0 angles
0 dihedrals
0 impropers
2 atom types
0 bond types
0 angle types
0 dihedral types
0 improper types
-22.964551 13.233451 xlo xhi
-21.790041 -9.475041 ylo yhi
-30.864607 -10.125607 zlo zhi
Masses
1 26.981539 # Al
2 63.546001 # Cu
Atoms
1 1 1 0.000000 -1.911010 -0.167990 -3.532720 # Al
2 2 1 0.000000 0.428050 -5.145990 -6.751170 # Al
3 3 1 0.000000 -1.332690 -10.253700 -10.130680 # Al
4 4 1 0.000000 1.006370 -15.231700 -13.349130 # Al
5 5 1 0.000000 -0.754370 -20.339411 -16.728649 # Al
6 6 1 0.000000 1.584690 -25.317400 -19.947100 # Al
7 7 1 0.000000 -0.176050 -30.425110 -23.326620 # Al
8 8 1 0.000000 -6.010810 -0.297700 -3.693790 # Al
9 9 1 0.000000 -3.671750 -5.275700 -6.912240 # Al
10 10 1 0.000000 -5.432490 -10.383410 -10.291760 # Al
11 11 1 0.000000 -3.093430 -15.361410 -13.510200 # Al
12 12 1 0.000000 -4.854170 -20.469120 -16.889721 # Al
13 13 1 0.000000 -2.515110 -25.447109 -20.108170 # Al
14 14 1 0.000000 -4.275860 -30.554819 -23.487690 # Al
15 15 1 0.000000 -10.110620 -0.427410 -3.854860 # Al
16 16 1 0.000000 -7.771550 -5.405410 -7.073310 # Al
17 17 1 0.000000 -9.532300 -10.513120 -10.452830 # Al
18 18 1 0.000000 -7.193240 -15.491120 -13.671280 # Al
19 19 1 0.000000 -8.953980 -20.598829 -17.050791 # Al
20 20 1 0.000000 -6.614920 -25.576820 -20.269239 # Al
**************** DATA TRUNCATED*************************
