Hello. I’m trying to test simulatiom between with/without gpu but there are several problems.
1st, when I use this input script,
DPD simulation unit
units lj
neighbor 1.5 bin
neigh_modify delay 1
atom_style bond
read_data data.dpd
#read_restart 2.restart
mass * 1.0
bond_style harmonic
bond_coeff 1 100 0.86
pair_style dpd 1.0 1.0 34387
pair_coeff 1 1 25.0 4.5
pair_coeff 1 2 25.0 4.5
pair_coeff 1 3 25.0 4.5
pair_coeff 1 4 25.0 4.5
pair_coeff 2 2 25.0 4.5
pair_coeff 2 3 25.0 4.5
pair_coeff 2 4 25.0 4.5
pair_coeff 3 3 25.0 4.5
pair_coeff 3 4 25.0 4.5
pair_coeff 4 4 25.0 4.5
special_bonds lj 0.0 1.0 1.0
comm_modify vel yes
fix 1 all nve
timestep 0.005
dump haha all xyz 5000 movie.xyz
restart 1000 1.restart 2.restart
thermo_style custom step temp pe ke etotal
thermo 100
run 10000
the run goes well. with command
cpu; mpirun -np 4 lmp_linux -in in.init
gpu; mpirun -np 4 lmp_linux -sf gpu -pk gpu 1 -in in.init
A problem is that when I use gpu acceleration, the simulation time becomes two times longer, especially because of “Pair time”
Sceond problem is that when I looked at a log.lammps file after simulation, it says
Total # of neighbors = 0
Ave neighs/atom = 0
Ave special neighs/atom = 0.25
I think this is more serious problem because total number of neighobors cannot be zero.
When I run without gpu, this problem doesn’t occur.(Like “Total # of neighbors = 18762940”)
Same problem occurs when I simulate with micelle, which is in examples directory
Do I have to change input script when I’m using gpu? or is this just a normal situation?(being “Total # of neighbors = 0”)
Or is there anything wrong in my script?
I use 10AUG2015 version of lammps, and Quadro K420
Thank you.
