Training Instability on Single-Element DFT Dataset with Variable Structure Sizes
Hi all,
I’m training a machine learning interatomic potential on dataset, which contains 61 DFT-calculated structures of (one element only). Each structure has a single frame, with total energy and atomic forces. The number of atoms varies significantly across the structures.
During training, I’m observing significant fluctuations in the energy and force loss , even though all data was generated consistently using the PBE functional.
I’ve already tried:
  • Lowering the learning rate
  • Gradually ramping the force and energy weights in the loss function
…but the loss still shows unstable behavior.
I’m looking for best practices or strategies to stabilize training when working with:
  • Variable-size structures
  • Total energy per frame (not normalized)
  • Single-element DFT data
Any insights into how to better handle this type of dataset ? would be greatly appreciated.
Thanks!
Hey @NoorAldinAlz the Materials Project forum is intended for support related to Materials Project data/software. If one of the model architectures you’re using is developed by groups within MP, e.g., M3GNet or CHGNet, happy to point you to their githubs for support.
