hello,
- Can we really convert a triclinic box of a 2D system into an orthogonal simulation box?
atom_style atomic
read_data mos2.dat
comm_modify cutoff 10.0
replicate 1 2 1
change_box all xy final 0.0
change_box all ortho
set group all image 0 0 0
write_data o-mos2.data
It works definitely, but I am a bit skeptical about it, because I see that the generated output alters the cell parameters slightly to make it orthogonal.
- Regarding the periodic boundary condition that I am supposed to input is ‘p p f’, because I need it to be periodic along the x- & y-directions and not in the z-direction. But, every time I apply the same it shows atoms are getting lost. So, I thought may be extending the box dimension along the z-axis, keeping the 2D- sheet right in between the box, is a good idea. But, I noticed the atoms in the sheet just disintegrates in all directions.
Am I doing everything wrong?
Regards
Bishwajit
