Translational diffusion of bulk water
Hi Axel and lampps users
I need to calculate the translational diffusion of bulk water for T=300K and P = 1atm. Does anyone have a tutorial explaining how to calculate the translational diffusion via lamps or MSD via post-processing?
I need it to answer a referee and I never calculated it.
Hi @Elizane_Moraes,
There are several ways of doing so and LAMMPS manual has a dedicated how-to section as well as dedicated examples and several discussions archived on the forum.
Adapting a script from the examples to use msd/chunk instead of msd to compute the diffusion constant of water molecules should be rather straight forward.
Please see Systematic errors in diffusion coefficients from long-time molecular dynamics simulations at constant pressure | The Journal of Chemical Physics | AIP Publishing for potential significant systematic errors in diffusivity of NPT simulations.
As an alternative to @Germain 's excellent answer, in this case I would often export the trajectory into a NumPy data structure with MDAnalysis and directly process the coordinates as numbers-over-time.
