I am new to LAMMPS, and I am using the stable 2, August 2023 version. I am trying to build LAMMPS using make mpi, and I have the Molecule, Manybody, KSPACE, and Rigid packages installed.
I am trying to install the Electrode Package. I tried to follow the instructions listed on this website (3.7. Packages with extra build options — LAMMPS documentation), and I used these commands:
make lib-electrode args=“-m mpi”
make lib-linalg args=“-m mpi”
The make mpi command works with the first four packages, but whenever I try to use it with the electrode package installed, I get an error that looks like this:
mpicxx -g -O3 -std=c++11 -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1 -c …/pppm_electrode.cpp
…/pppm_electrode.cpp(765): error: expected a “;”
double *_noalias xi_ele = x_ele[ipos];
…/pppm_electrode.cpp(768): error: identifier “xi_ele” is undefined
int nix = static_cast((xi_ele[0] - boxlo[0]) * delxinv + shift) - OFFSET;
…/pppm_electrode.cpp(883): error: expected a “;”
…/pppm_electrode.cpp(886): error: identifier “xi_ele” is undefined
compilation aborted for …/pppm_electrode.cpp (code 2)
make[1]: *** [Makefile:114: pppm_electrode.o] Error 2
make[1]: Leaving directory ‘/jet/home/dlee5/lammps-2Aug2023/src/Obj_mpi’
make: *** [Makefile:397: mpi] Error 2
Can someone help me with what I am doing wrong to install the package?
Thank you!
