Dear Lammps Users,
This is a question that has been discussed many times before – but I could not find the answer that I am specifically looking for.
What LAMMPS says:
since derivatives are identical (if I cut off anywhere above sigma), the trajectories and forces are identical. Relevant details from LAMMPS manual on pair_modify shift yes – “If so, this adds an energy term to each pairwise interaction which will be included in the thermodynamic output, but does not affect pair forces or atom trajectories.”
My Simulations:
I performed two simulations (one with truncated and other with truncated/shifted LJ, i.e., with and without pair_modify shift yes at 2^(1/6) sigma). I understand there is discontinuity in potential and force for case 1 and latter for case 2. Now to the question. I printed intensive evdwl from thermodynamic output with both the cases, and it gives identical results. Why is it so? Shouldn’t the extra offset be reflected in this or am I missing something. Relevant code details and outputs are give below. Please let me know if you need the full code and I shall provide the same.
Pair Information
bond_style fene
special_bonds fene
bond_coeff 1 30 1.6 1.5 1
angle_style cosine
angle_coeff 1 3
dihedral_style none
improper_style none
pair_style lj/cut/coul/long 1.122462 10.0
pair_coeff * * 1 1
kspace_style pppm 0.00001
kspace_modify slab 3.0
dielectric 1
#pair_modify shift yes #it is uncommented for shifted/truncated.
#Run/Print styles
fix 2 not_bottom langevin 1 1 6.99 904297 #not bottom is about 99% of total number of atoms
thermo_style custom step temp pe evdwl epair
thermo 10
run 100
Output:
With pair_modify yes
Step Temp PotEng E_vdwl E_pair
10285000 0.99044634 12.430849 0.0092685482 -0.23489335
10285010 0.99945363 12.41542 0.0070048401 -0.23700893
10285020 1.0001562 12.415137 0.0088646568 -0.23517801
10285030 0.98889901 12.432286 0.0086868613 -0.23548373
10285040 0.99976159 12.421335 0.008177021 -0.23611516
10285050 1.0043689 12.416264 0.0083009996 -0.23617625
10285060 0.99181344 12.437931 0.0099223853 -0.23468554
10285070 1.0077589 12.413876 0.0090538319 -0.23559688
10285080 1.0015782 12.424655 0.0075691142 -0.23696984
10285090 1.0042804 12.420705 0.0097466878 -0.23470351
10285100 1.0026287 12.426541 0.0094367655 -0.2346721
Loop time of 9.14612 on 1 procs for 100 steps with 6700 atoms
With no pair_modify yes
Loop time of 9.14048 on 1 procs for 100 steps with 6700 atoms
Total # of neighbors = 715493
Ave neighs/atom = 106.79
Ave special neighs/atom = 1.1606
Neighbor list builds = 5
Any help will be greatly appreciated.
