Hey I am trying to run a program to get initial configuration for polyurethane, but it is not working I donβt know what I am doing wrong or if I need to change something which I doubt, for other structures I get what I need here is my code
pressure 1.0
lammps true
ITEM END
ITEM GROUPS
polyurethane CCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC)cc1)cc2,1,polyurethane:2
terma *C,1,polyurethane:1
termb *C,1,polyurethane:2
ITEM END
ITEM CLUSTERS
polymer block,50
ITEM END
ITEM POLYMERS
polymer
1 polyurethane,10,terma,1,termb,1
ITEM END
theses are the error I am finding
-MacBook-Pro butene16 % emc_macos build.emc
(* EMC: Enhanced Monte Carlo simulations *)
version 9.4.4, build Aug 8 2023 07:32:32, date Mon Feb 12 00:42:58 2024
valid until Jul 31, 2024
Info: script v1.0 started at Mon Feb 12 00:42:58 2024
Info: variables = {seed β -1, ntotal β 10000, fshape β 1, output β
βbutene16β, field β βpcff/pcffβ, location1 β
β/Applications/v9.4.4/field/β, nav β 0.6022141179, temperature β
300, radius β 5, nrelax β 100, weight_nonbond β 0.0001, weight_bond
β 0.0001, weight_focus β 1, cutoff β 9.5, charge_cutoff β 9.5,
kappa β 4, density1 β 1, lprevious β 0, lphase β 0, f_polymer β
50, chem_polyurethane β βCCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC)cc1)cc2β,
chem_terma β βCCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC*)cc1)cc2β, chem_termb
β βCCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC)cc1)cc2"}
Info: output =
{detail β 3, wide β false, expand β false, math β true, reduced β
false, info β true, strict β true, warning β true, message β true,
debug β false, exit β true, ignore β false}
Info: field = {id β pcff, mode β cff, style β none, name β
{β/Applications/v9.4.4/field/pcff/pcff.frcβ,
β/Applications/v9.4.4/field/pcff/pcff_templates.datβ}, compress β
false, error β true, debug β false, check β {atomistic β true,
charge β true}}
Info: importing β/Applications/v9.4.4/field/pcff/pcff.frcβ
Warning: duplicate field.bond entry 40 [c:c] omitted.
Warning: duplicate field.bond entry 51 [c:h] omitted.
Warning: duplicate field.bond entry 62 [c:o_2] omitted.
Warning: duplicate field.bond entry 176 [c=:c=1] omitted.
Warning: duplicate field.bond entry 328 [c_1:o_1] omitted.
Warning: duplicate field.bond entry 364 [cp:cp] omitted.
Warning: duplicate field.bond entry 365 [cp:cp] omitted.
Warning: duplicate field.bond entry 367 [cp:h] omitted.
Warning: duplicate field.bond entry 689 [o:p] omitted.
Info: groups = {ngroups β 3, group β {
{id β polyurethane, chemistry β
βCCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC)cc1)cc2β, depth β 8, charges
β forcefield, charge β 0, terminator β false, nconnects β 4,
connects β {
{source β $end1, destination β {index β polyurethane, site β
$end2}},
{source β $end1, destination β {index β terma, site β
$end1}},
{source β $end2, destination β {index β polyurethane, site β
$end1}},
{source β $end2, destination β {index β termb, site β
$end1}}}},
{id β terma, chemistry β
"CCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC)cc1)cc2β, depth β 8, charges β
forcefield, charge β 0, terminator β false, nconnects β 1,
connects β
$end1}}},
{id β termb, chemistry β
β*CCOC(=O)Nc2ccc(Cc1ccc(NC(=O)OCC)cc1)cc2β, depth β 8, charges β
connects β
$end2}}}}, ndeletes β 0, npolymers β 0}
Info: field = {mode β apply, style β none, error β true, debug β false,
check β {atomistic β true, charge β true}, increment β warn}
Info: applying β/Applications/v9.4.4/field/pcff/pcff.frcβ
Warning: increment pair {o_2, c-} set to zero.
Warning: increment pair {c-, na} set to zero.
Info: variables = {lg_polyurethane β 45, lg_terma β 46, lg_termb β 46,
norm_polymer β 1, l_polymer β 542, mg_polyurethane β 340.38225,
mg_terma β 341.39022, mg_termb β 341.39022, m_polymer β 4086.60294,
n_polymer β 50, ntotal β 0, mtotal β 0}
Info: simulation = {units β {permittivity β 1, seed β seed}, types β {
coulomb β {pair β {active β true, cutoff β charge_cutoff}}}}
Info: clusters = {progress β none, nbodys β 0, nclusters β 0, ngrafts β 0,
npolymers β 1,
polymer β
{id β polymer, system β main, type β block, niterations β 1000, n
β 50, groups β {polyurethane, terma, termb}, weights β {1, 1, 1},
nrepeat β {10, 1, 1}}}
delta = {systems β 1, bodies β 0, clusters β 50, sites β 27100}
Warning: no torsion coefficients found for {c, c, o_2, c-}.
Warning: no torsion coefficients found for {hc, c, o_2, c-}.
Error: core/script/field/entry.c:641 ScriptFieldEntryApply:
Missing force field parameters.
Program aborted.
