Ttm/mod
Hello developer, my model setup is shown below. There are vacuum layer, Newton layer, constant temperature layer and fixed layer. I use ttm/mod command to simulate femtosecond laser with two-temperature model。
compute ke all ke/atom
variable temp atom c_ke/1.5/8.625e-5
compute layers all chunk/atom bin/1d z lower 0.025 units reduced
fix 2 all ave/chunk 2 5 100 layers v_temp file temp.txt
This temperature calculation I selected all the areas, including the fixed layer, but the speed of the fixed layer is 0, so I think there are some problems in temperature calculation.
But if I choose to calculate temperature using only Newtonian layers, does his chunk/atom layer divide only Newtonian layers?。
And his output file shows that atoms and temperatures are also present in the vacuum layer region.。
Hello, the model I set is the same as yours. It includes the vacuum layer, the Newton layer, the constant temperature layer, and the fixed layer. I found that setting the space specified by ttm/mod (such as all the boxes or only the Newton layer) did not affect the result. However, according to the manual, this situation should not occur this output. I also encountered the same confusion as you. Do you found a proper explanation for this problem.Hope to receive response from you. Wish you all the best in your work. Thank you.
