Many thanks for your comments. But for the first question, you may like to run attached simple example. The simulation can not run with the basis-1.cor, but everything is ok with the basis-2.cor, although these two files contains the same basis atoms.
that is because your basis-1.cor file has an "&"
at the end of the last line and thus combining its
content with the *next* input line from your in.test
file and thus giving an error.
sorry, but this is not LAMMPS' fault but a case of PEBCAC.
LAMMPS is doing exactly what it claims it does.
