I am trying to define a lammps input script that gets a list of forcefield files and for each forcefield file it runs simulations in multiple temperatures. One way to do this is to make an outer Uloop for force field files and an inner loop for the temperature. However, is it possible to make both loops as uloop?
What do you expect to gain from this? I can only see disadvantages versus writing a bash script that generates the NxM input files and submit them as individual calculations.
I do this because I want to run multiple simulations at the same time using the same input script. If I loop over the parameters in the job file then at each time only one simulation will be running on the allocated processors.
So there is no benefit. You would not loop in the input but rather generate one input for each iteration and run these independently. This has multiple benefits:
if one of the simulations has an issue, the others are unaffected. With running this from one input all calculations stop on any issue
one most queueing systems you have to wait longer for bigger/longer jobs. With many small jobs, you can them often “sneak” them in the so-called backfill
those many small submissions would run concurrently as you submit them
If memory serves me correctly, @srtee has explained the same to you before.
