When trying to import the api module, I get the error “TypeError: SeparationPlane.init() got an unexpected keyword argument ‘point_groups_permutations’”. This code worked around a week or two ago, but no longer does. This occurs from just importing, so I’m unsure what is causing this. I’ve tried reinstalling modules, updating them, and running on different versions of Python but error still occurs. Sorry if this is a noob question, and thank you in advanced for any solutions.
The full error is as follows:
TypeError Traceback (most recent call last)
Cell In[8], line 3
1 import numpy
2 import pandas
----> 3 from mp_api.client import MPRester
5 with MPRester("my-api-key") as mpr:
6 docs = mpr.materials.summary.search(formula=[formula], fields=[ 'material_id',
7 'formation_energy_per_atom',
8 'band_gap',
13 'spacegroup.number',
14 'database_IDs'])
File ~\.conda\envs\myenv\Lib\site-packages\mp_api\client\__init__.py:8
5 from importlib.metadata import PackageNotFoundError, version
7 from .core import MPRestError
----> 8 from .mprester import MPRester
10 try:
11 __version__ = version("mp_api")
File ~\.conda\envs\myenv\Lib\site-packages\mp_api\client\mprester.py:31
29 from mp_api.client.core.utils import validate_ids
30 from mp_api.client.routes import GeneralStoreRester, MessagesRester, UserSettingsRester
---> 31 from mp_api.client.routes.materials import (
32 AbsorptionRester,
33 AlloysRester,
34 BandStructureRester,
35 BondsRester,
36 ChemenvRester,
37 DielectricRester,
38 DOIRester,
39 DosRester,
40 ElasticityRester,
41 ElectrodeRester,
42 ElectronicStructureRester,
43 EOSRester,
44 GrainBoundaryRester,
45 MagnetismRester,
46 OxidationStatesRester,
47 PhononRester,
48 PiezoRester,
49 ProvenanceRester,
50 RobocrysRester,
51 SimilarityRester,
52 SubstratesRester,
53 SummaryRester,
54 SurfacePropertiesRester,
55 SynthesisRester,
56 TaskRester,
57 ThermoRester,
58 XASRester,
59 )
60 from mp_api.client.routes.materials.materials import MaterialsRester
61 from mp_api.client.routes.molecules import MoleculeRester
File ~\.conda\envs\myenv\Lib\site-packages\mp_api\client\routes\materials\__init__.py:5
3 from .absorption import AbsorptionRester
4 from .bonds import BondsRester
----> 5 from .chemenv import ChemenvRester
6 from .dielectric import DielectricRester
7 from .doi import DOIRester
File ~\.conda\envs\myenv\Lib\site-packages\mp_api\client\routes\materials\chemenv.py:5
1 from __future__ import annotations
3 from collections import defaultdict
----> 5 from emmet.core.chemenv import (
6 COORDINATION_GEOMETRIES,
7 COORDINATION_GEOMETRIES_IUCR,
8 COORDINATION_GEOMETRIES_IUPAC,
9 COORDINATION_GEOMETRIES_NAMES,
10 ChemEnvDoc,
11 )
13 from mp_api.client.core import BaseRester
14 from mp_api.client.core.utils import validate_ids
File ~\.conda\envs\myenv\Lib\site-packages\emmet\core\chemenv.py:4
1 from typing import Literal, List, Union, Optional
3 from pydantic import Field
----> 4 from pymatgen.analysis.chemenv.coordination_environments.chemenv_strategies import (
5 SimplestChemenvStrategy,
6 )
7 from pymatgen.analysis.chemenv.coordination_environments.coordination_geometries import (
8 AllCoordinationGeometries,
9 )
10 from pymatgen.analysis.chemenv.coordination_environments.coordination_geometry_finder import (
11 LocalGeometryFinder,
12 )
File ~\.conda\envs\myenv\Lib\site-packages\pymatgen\analysis\chemenv\coordination_environments\chemenv_strategies.py:46
42 __date__ = "Feb 20, 2016"
44 module_dir = os.path.dirname(os.path.abspath(__file__))
---> 46 MPSYMBOL_TO_CN = AllCoordinationGeometries().get_symbol_cn_mapping()
47 ALLCG = AllCoordinationGeometries()
50 class StrategyOption(MSONable, abc.ABC):
File ~\.conda\envs\myenv\Lib\site-packages\pymatgen\analysis\chemenv\coordination_environments\coordination_geometries.py:894, in AllCoordinationGeometries.__init__(self, permutations_safe_override, only_symbols)
892 with open(cg_file) as file:
893 dd = json.load(file)
--> 894 self.cg_list.append(CoordinationGeometry.from_dict(dd))
895 else:
896 for symbol in only_symbols:
File ~\.conda\envs\myenv\Lib\site-packages\pymatgen\analysis\chemenv\coordination_environments\coordination_geometries.py:626, in CoordinationGeometry.from_dict(cls, dct)
598 @classmethod
599 def from_dict(cls, dct: dict) -> Self:
600 """
601 Reconstructs the CoordinationGeometry from its JSON-serializable dict representation.
602
607 CoordinationGeometry
608 """
609 return cls(
610 mp_symbol=dct["mp_symbol"],
611 name=dct["name"],
612 alternative_names=dct["alternative_names"],
613 IUPAC_symbol=dct["IUPAC_symbol"],
614 IUCr_symbol=dct["IUCr_symbol"],
615 coordination=dct["coordination"],
616 central_site=dct["central_site"],
617 points=dct["points"],
618 solid_angles=(
619 dct["solid_angles"]
620 if "solid_angles" in dct
621 else [4.0 * np.pi / dct["coordination"]] * dct["coordination"]
622 ),
623 deactivate=dct["deactivate"],
624 faces=dct["_faces"],
625 edges=dct["_edges"],
--> 626 algorithms=[MontyDecoder().process_decoded(algo_d) for algo_d in dct["_algorithms"]]
627 if dct["_algorithms"] is not None
628 else None,
629 equivalent_indices=dct.get("equivalent_indices"),
630 neighbors_sets_hints=[
631 cls.NeighborsSetsHints.from_dict(nb_sets_hints)
632 for nb_sets_hints in dct.get("neighbors_sets_hints") or []
633 ]
634 or None,
635 )
File ~\.conda\envs\myenv\Lib\site-packages\monty\json.py:716, in MontyDecoder.process_decoded(self, d)
713 data = {k: v for k, v in d.items() if not k.startswith("@")}
714 if hasattr(cls_, "_from_dict"):
715 # New functionality with save/load requires this
--> 716 return cls_._from_dict(
717 data, name_object_map=self._name_object_map
718 )
719 if hasattr(cls_, "from_dict"):
720 return cls_.from_dict(data)
File ~\.conda\envs\myenv\Lib\site-packages\monty\json.py:247, in MSONable._from_dict(cls, d, name_object_map)
244 @classmethod
245 def _from_dict(cls, d, name_object_map):
246 decoded = MSONable.decoded_from_dict(d, name_object_map=name_object_map)
--> 247 return cls(**decoded)
TypeError: SeparationPlane.__init__() got an unexpected keyword argument 'point_groups_permutations'
