TypeError: can't multiply sequence by non-int of type 'float'
on my WSL - Ubuntu I installed all openkim packages.
But the second testing program for ASE OpenKIM · Using KIM Models · Interatomic Potentials and Force Fields gives the error
python3 coh_en2.py
  File "/mnt/c/Users/milias/Documents/git-projects/open-collection/theoretical_chemistry/software/openkim/buildup_on_servers/jinr_ru/wsl_win10_pc7321b/cohesive_energy_fcc_aluminium/coh_en2.py", line 19, in <module>
    atoms = FaceCenteredCubic("Al", latticeconstant=a0)
  File "/home/milias/.local/lib/python3.10/site-packages/ase/lattice/bravais.py", line 79, in __call__
    self.make_crystal_basis()
  File "/home/milias/.local/lib/python3.10/site-packages/ase/lattice/cubic.py", line 47, in make_crystal_basis
    self.crystal_basis = (self.latticeconstant * self.basis_factor
Hi Miroslav,
The query site is currently down, so the variable a0 ends up having something other than a floating point number in it. You can confirm by going to https://query.openkim.org, and seeing that none of the example queries work.
It may not be up until after the weekend, unfortunately. A workaround you can use to continue testing your installation is to find the lattice constant on the website:
You can find “Equilibrium zero-temperature lattice constant for fcc Al” and click “expand” to see the lattice constant. Then you can set a0=4.032082033157349 in your script manually instead of querying for it.
Sorry about this! We are working on making our query site more reliable.
Cheers, ilia
Hi Miroslav,
The query site is back up.
OK, it works now:
milias@Miro:/mnt/c/Users/miroi/OneDrive/Desktop/Work/projekty/open-collection/theoretical_chemistry/software/openkim-ase/buildup_on_servers/jinr_ru/wsl_win10_pc7321b/cohesive_energy_fcc_aluminium/.python3 coh_en2.py
doing query to get lattice constant for this model= EAM_Dynamo_ErcolessiAdams_1994_Al__MO_123629422045_005
obtained a0= 4.032082033157349
/mnt/c/Users/miroi/OneDrive/Desktop/Work/projekty/open-collection/theoretical_chemistry/software/openkim-ase/buildup_on_servers/jinr_ru/wsl_win10_pc7321b/cohesive_energy_fcc_aluminium/coh_en2.py:26: DeprecationWarning: Please use atoms.calc = calc
  atoms.set_calculator(calc)
Computed cohesive energy of 3.360 eV/atom (experiment: 3.39 eV/atom)
Computed pressure of -0.0036923616494566416 MPa
