Dear Alex
I got this error when I tried to do parallel computation, here’s my script and the parameters I set.
I have tried different nworkers parameters, but finally found that only the default value can run, but this is a great test to the memory, the cluster will always be overloaded with memory, causing the whole cluster to crash.
amset.pbs (660 Bytes)
settings.yaml (937 Bytes)
LLei
