Recently OVITO quit rendering all frames in the animation. Now it only renders the first frame. I am wondering if it was something I set wrong, or if it is a bug. Changed all of the rendering settings with the same result. Even exported to an mp4 file and got the same result. Any help would be appreciated.
There is no enough pieces of information to diagnose the problem. Perhaps be more specific. Are you making sure you are uploading a lammpstrj file containing multiple frames? Are you making sure you are checking the box to indicate to Ovito that this file has multiple frames? Did you update your Ovito version recently?
Thank you for the response. I have had the problem in my older version, so I upgraded to the current version (not Pro). I am not seeing a box to check that directs it to find multiple frames. Can you tell me where this box is located? Thanks.
Are you looking for these options perhaps?
The red ones are for loading a series of snapshot files as an animation.
The green one is for loading a single file containing an entire trajectory.
For more info, see:
https://ovito.org/docs/dev/usage/import.html#usage-import-sequence
https://ovito.org/docs/dev/reference/pipelines/data_sources/external_file.html
Thank you for your help. I have found all the options and am having no further problems!
