Unable to install nomad-lab
!pip install nomad-lab
Collecting nomad-lab
  Using cached nomad-lab-1.2.1.tar.gz (21.6 MB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Preparing metadata (pyproject.toml) ... done
Collecting numpy~=1.22.4 (from nomad-lab)
  Using cached numpy-1.22.4.zip (11.5 MB)
  Getting requirements to build wheel ... error
  error: subprocess-exited-with-error
  × Getting requirements to build wheel did not run successfully.
  │ exit code: 1
  ╰─> [33 lines of output]
        File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 112, in get_requires_for_build_wheel
          backend = _build_backend()
        File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 77, in _build_backend
          obj = import_module(mod_path)
        File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/importlib/__init__.py", line 90, in import_module
          return _bootstrap._gcd_import(name[level:], package, level)
        File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
        File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
        File "<frozen importlib._bootstrap>", line 1310, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
        File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
        File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
        File "<frozen importlib._bootstrap_external>", line 995, in exec_module
        File "/private/tmp/pip-build-env-2rvek0qv/overlay/lib/python3.12/site-packages/setuptools/__init__.py", line 16, in <module>
          import setuptools.version
        File "/private/tmp/pip-build-env-2rvek0qv/overlay/lib/python3.12/site-packages/setuptools/version.py", line 1, in <module>
          import pkg_resources
        File "/private/tmp/pip-build-env-2rvek0qv/overlay/lib/python3.12/site-packages/pkg_resources/__init__.py", line 2172, in <module>
          register_finder(pkgutil.ImpImporter, find_on_path)
      AttributeError: module 'pkgutil' has no attribute 'ImpImporter'. Did you mean: 'zipimporter'?
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
and then when i install the latest nomad-lab instead:
[nomad/docs/howto/programmatic/pythonlib.md at d859990196ee4f15409e1ae4d933d10adacdabfc · nomad-coe/nomad · GitHub]
!pip install nomad-lab --extra-index-url https://gitlab.mpcdf.mpg.de/api/v4/projects/2187/packages/pypi/simple
from nomad.client.archive import ArchiveQuery
required = {
        'include': ['entry_id','mainfile']
query = {
        'datasets.dataset_id': 'ZFqQC76ARYWFPCTJGyj7Gw',
        'mainfile': 'AminoAcids/argH/*'
query = ArchiveQuery(query=query, required=required, page_size=10, results_max=10000)
ModuleNotFoundError: No module named ‘nomad.client’; ‘nomad’ is not a package
I am new to NOMAD, so I am not sure.
According to the base linux install instructions of fairmat NOMAD, I see that the requirement is python3.9
It looks like you are using python3.12
Hello!
Earlier versions of nomad might not support py3.12 as sherin suggested.
But the latest versions available from gitlab index supports py3.12 now.
For the latest version, are you using a virtual env and was it activated when you installed the package and tried to import nomad?
I have no experience installing it in base linux. I am just trying to use the docker-based one. I am curious to know if there a specific reason why you are installing everything manually instead of using the docker-based solution?
