Unable to obtain a new API Key
Thank you for reading this. I am trying to get new API Key, and want to discard my legacy API. How can I do that? I’ve tried generating new API from the dashboard menu but it is not generating new API key.
I will appreciate your help.
Merci Thank you
Thanks for reaching out and reporting this. We’re aware of the issue and are planning to roll out a fix today. I’ll follow up with an update here.
Thank you, am trying to get Stiffness tensors for a bunch of materials and unable to do so using legacy API key in pyhton. The upgraded pymatgen asking for new api key.
I see. That’s actually not related to the issue I mentioned. You can find your new API key at https://materialsproject.org/api or https://materialsproject.org/dashboard once you’re logged in. Note that all legacy services will be retired in September.
Hi, Thank you again. I tried it but unable to get new API key.
There’s no need to “get a new API key” by pushing the button on your dashboard. Simply copy the one displayed. HTH
